Author Topic: 1.8T stroker kits - talk to me!  (Read 705 times)
Offline Chris.
« on: 09 February 2012, 16:27 »
Thought of a stroker kit on a 1.8T when money allows.  Obviliously its designed for big turbo setups but im wondering what parts you need to make it?
Ive heard you use a 2.0 FSI crank and a long time ago you can use a 1.9 crank?
What parts are needed to be swapped over if you were to build your own kit?  I guess you need to press the oil ring gear onto the crank on for the 1.8T oil pump, but what other modifications are needed?
A lot of kits seem to come with pistons?  Are they needed as well as a block overbore or not?  Rods would be ran either way and I guess you can stil use the 144mm/20mm rods that you normally use for a 1.8T?
Whats the reliability like?
Just probing into the kits to help make a decision really.
Chris
Click For Build Thread
