Author Topic: Do i need a new rear caliper ?  (Read 898 times)
Offline gm8
« on: 09 February 2012, 13:19 »
I replaced my rear discs/pads the other day. In the past my o/s rear caliper gave me grief , the lever the operates the handbrake would not fully release. Now I have the same prob again. The piston seems fine , it wound back in normally , but the handbrake lever is stiff and wont really come back when i release the handbrake. I coated in wd40 and moved it about with mole grips etc. Is this part serviceable or do I need a new caliper ?
Offline stevelfc
Re: Do i need a new rear caliper ?
« Reply #1 on: 09 February 2012, 19:16 »
try this as my sister's golf did the same as your's so i soaked in gt85 same as wd40 but better and did  this mod click on link only cost few quid for the parts and never no problems since  :wink:
http://www.clubgti.com/forum/showthread.php?t=207880
Offline gm8
« Reply #2 on: 09 February 2012, 20:20 »
cheers for that , think i managed to sort  today
« Reply #3 on: 09 February 2012, 23:46 »
If the caliper is seizing up it is better in the long run to just replace it.
Offline gm8
« Reply #4 on: 10 February 2012, 10:18 »
turned out to be the cables actually. After I got the cable off the lever was free and moved to the stop with ease. I spent ages cleaning/lubing the cable and hen re adjusted it all (new cable would be ideal but I needed to fix it there and then) now its all sorted and will replace cables asap.
Offline Steve_PD
« Reply #5 on: 10 February 2012, 13:26 »
The cable is inside a nylon sleeve which breaks down over time and cause the cable to jam. Think I bought a pair of cable of ebay for -£30, pretty easy to fit.
