Author Topic: Lay flat wiper  (Read 1361 times)
Judderi
Lay flat wiper
« on: 20 May 2005, 10:18 »
Hi guys and girls.
The bodyshop are having a little trouble with the rear wiper. Its not parking in the right place. What needs to be done in order for the rear wiper to be laid flat. Im sure its been asked before but the search doesent work and i cant be bothered trawling through millions of posts. It used to lay flat before it was taken apart.
Offline Gambit
Re: Lay flat wiper
« Reply #1 on: 20 May 2005, 11:40 »
as you look at it from underneath
in the off position the crank/arm of the wiper motor has to go back on itself. i.e. the small arm points to 9 oclock and then the big arm (connecting to spindle) goes back pointing to 3 o'clock.
then refit the actual wiper arm so that it lies perfectly flat
Judderi
Re: Lay flat wiper
« Reply #2 on: 20 May 2005, 11:43 »
Cheers gambit
Offline 92 rocks
Re: Lay flat wiper
« Reply #3 on: 22 May 2005, 15:49 »
Bit of a worry mate if  a bodyshop cant configure the rear wiper isnt it?  :shocked:
Stuck in the 80s? Nope its a 92!
Offline Agreeable Slick
  • Unit
Re: Lay flat wiper
« Reply #4 on: 22 May 2005, 16:34 »
was just about to mention if they cannot figure that out how good of a body shop are they really??
 :undecided: :undecided:
Judderi
Re: Lay flat wiper
« Reply #5 on: 23 May 2005, 13:22 »
The guy just couldent figure out how to get in to lay flat when parked. Not his fault really as there not supposed to lay flat.
