Author Topic: Can a coolant temp sensor not work and not show a vag error  (Read 830 times)
Offline carpetviper
I have just ran out of petrol after doing 35 miles on £15.
So I have been looking into possible causes for this shocking mpg and I wondered if it could be the coolant temp sensor.
I have already fitted a new maf sensor and a new lambda.
I have done a vag reading and not come up with any errors and it has just passed the mot last week so emmissions should be ok.
Which coolant sensor would I need.
Offline javalin
Re: Can a coolant temp sensor not work and not show a vag error
« Reply #1 on: 09 February 2012, 20:00 »
I would say yes, unless its completely died.
the correct one for your engine!
james
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 09 February 2012, 20:17 »
vag-com wont show a faulty temp sensor, there's a couple and you need to check the colour to get the correct one (remove look and push back in)
