Author Topic: quick question temp sensor/ thermostat  (Read 1035 times)
Offline stevelfc
« on: 08 February 2012, 06:52 »
on a mk4 golf 1.8.t we all know if a temp sensor is playing up or faulty it can increase fuel compustion and give running problems but is this the same if a thermostat is faulty ? As it's not doing it's job .
Why i ask is my gauge goes up to 90 if car stationry but soon as you drive it starts to drop back down ( need new thermostat ) so one minute the gauge will be normally 90 next minute back down to cold .
so if a car engine is cold the car adjusts fuel mixture.e.t.c. because it thinks it got to get to running temp but if its always running cold due to knacked thermostat surley the car adding more fuel e.t.c
Offline Granta Gti
Re: quick question temp sensor/ thermostat
« Reply #1 on: 08 February 2012, 13:21 »
That does sound like thermo. It will use a bit more fuel, not a huge amount more but will run richer.
Offline barrym381
« Reply #2 on: 08 February 2012, 20:44 »
change both they are cheap an easy to do :smiley:
Offline stevelfc
« Reply #3 on: 08 February 2012, 20:47 »
done temp sensor , water pump so next thermostat
« Reply #4 on: 09 February 2012, 00:08 »
Did you use a genuine temp sender.
