Author Topic: Valve stem oil seals  (Read 3130 times)
Offline jimmy_gti
« on: 07 February 2012, 22:29 »
Does anybody know if you can do the valve stem oil seals without taking off the head? Or does anybody know where i can get them done for a good price thanks
Offline jimmy_gti
Re: Valve stem oil seals
« Reply #1 on: 07 February 2012, 22:30 »
In stoke on trent area
Offline james2
  • No scammers please.
« Reply #2 on: 07 February 2012, 23:19 »
head will need taking off
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline harlemex
« Reply #3 on: 08 February 2012, 14:38 »
Its possible to do it with the head on, but difficult. You need a tool to stop the valves dropping.
« Reply #4 on: 09 February 2012, 00:09 »
Can be done with compressed air.
Offline LowlifeDubber
« Reply #5 on: 09 February 2012, 07:32 »
Get one of these
Screw it into your sparkplug hole on the pot your working on.Get the piston to tdc and apply 80-90psi of air.This will pressurize the cylinder and hold your valve in place.
Simples :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 09 February 2012, 08:49 »
Don't the valves rest on the top of the pistons if they at TDC?
« Reply #7 on: 09 February 2012, 14:16 »
Yes but it is usually too far of a drop to be able to lift the valve up enough to get the collets on.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 09 February 2012, 14:27 »
I'm just thinking back my Ford days  :grin:
Offline richw911
« Reply #9 on: 09 February 2012, 14:36 »
Which engine? Do they really need replacing? Whats up smoke on start up?
