Author Topic: pedal box  (Read 3252 times)
Offline D Squared
pedal box
« on: 07 February 2012, 21:26 »
my clutch cable outer support pedastal has come off, the weld has broke at top of pedal box...anyone else had this issue?
pedal box looks like a right cow to get out.. steering column to be moved up out of the way...
Any tips?
DD
MK3-MK5- Now MK7 GTi
Offline Khare
  • The bear that khares
Re: pedal box
« Reply #1 on: 07 February 2012, 21:28 »
And you also need to remove the center console as the pedal box goes all the way to the passenger footwell.
Offline benvictors
  • bgk Tuning - coming soon!!!
Re: pedal box
« Reply #2 on: 07 February 2012, 21:37 »
Nope!!
Dash out, steering column out, pedalbox out.
The accelerator is bolted to the bulk head, not the pedalbox  :wink:
Offline Khare
Re: pedal box
« Reply #3 on: 07 February 2012, 21:40 »
Nope!!
Indeed. But OP is talking about clutch...
Offline benvictors
Re: pedal box
« Reply #4 on: 07 February 2012, 22:17 »
Indeed he is, but the pedalbox doesn't go through to the passenger side, it is literally just the brake pedal and clutch pedal on a bracket, bolted through the bulk head. Its just the accelerator that runs through to the passenger side, behind all the center console heating gubbings  :cool:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: pedal box
« Reply #5 on: 07 February 2012, 23:07 »
Ben speaks the truth
here is a late mk3 one with provisions for hydro  (early ones are same but won't accept hydro)
http://www.ebay.co.uk/itm/VW-MK3-GOLF-VR6-PEDAL-BOX-COLUMN-HYDRAULIC-/320844800433?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4ab3d721b1#ht_1821wt_940
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Khare
Re: pedal box
« Reply #6 on: 07 February 2012, 23:21 »
Ah right, I thought it ran through to passenger side too. Nice to know it's not THAT much of a ballache if it does ever need doing  :grin:
Offline D Squared
Re: pedal box
« Reply #7 on: 08 February 2012, 07:15 »
all i know its a right pain getting it out, especially when shear bolts are involved on the column, and there are 2 other bolts that go from a pedal box support bracket bolt through from the cabin area to the tunnel... can't even get/see too them..!! Oh what fun..!!
Offline Callum_K
Re: pedal box
« Reply #8 on: 04 February 2014, 11:51 »
Sorry to bump an Old thread but this just happened to me too…how’d you get on in the end?
