Author Topic: New bolts -suspension change  (Read 1611 times)
Offline Shivas Regal
« on: 07 February 2012, 20:50 »
Im about to embark on aftermarket suspension for my 16v
Was wondering if I should be changing any old bolts in the process.
I want to get everything u need before I start dismantling
Offline X4MGS
  • VAG Parts SNOB!!!
Re: New bolts -suspension change
« Reply #1 on: 07 February 2012, 20:53 »
I would... I did every thing when I did mine...
Top Mounts, Bump Stops, Nuts & Bolts etc..... No point doing half the job!!
For More Info Click To See;
Offline Sam
  • Sam I am
« Reply #2 on: 07 February 2012, 23:11 »
You can still get the original camber bolts from vw. One should be 'thinner' in the middle than the other. As stated top mounts (mk3 I read somthing about???) and the few holding bolts that keep the suspension together with I wouldnt bother with. You may want to look into doing your bushings whilst your at it but thats up to do, I didnt but I probs should have done for the sake of £20  :smiley:
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 07 February 2012, 23:16 »
Stick G3 GTI top mounts on the set up - stronger, more hard-wearing.
You will need the top metal plates to go with.
« Reply #4 on: 08 February 2012, 08:08 »
The metal caps.... Are they the spring caps?
  • Opinions я Us
« Reply #5 on: 09 February 2012, 13:06 »
NO, they go on top of the top mounts, in the engine bay.
You will may need spring caps as well.
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #6 on: 09 February 2012, 14:07 »
