Author Topic: 12 years SORN  (Read 7662 times)
Offline Sam
  • Sam I am
Re: 12 years SORN
« Reply #10 on: 07 February 2012, 23:32 »
Remove the fuel pump fuse and centre ignition lead, and crank over on the starter.
Beter than that - take the plugs out and spin it over to build oil pressure - much less effort needed from the battery.
Brake lines shouldn't be rusted out unless it was left with old fluid in it that was full of water.  :rolleyes:
Get it running, do the fluid changes and be prepared for a couple of breakdowns.
Might be worth changing the cambelt before you do too much - has the most potential to stop the whole shooting match dead in its tracks.
I thought they were non intrusive anyhow?
Offline AudiA8Quattro
Re: 12 years SORN
« Reply #11 on: 08 February 2012, 11:18 »
Good point about removing the plugs.
Would you recommend turning it over by hand first?
Offline Ben Lessani
Re: 12 years SORN
« Reply #12 on: 08 February 2012, 16:40 »
If you concerned about the engine being siezed, pop it in gear and give it a rock/push :)
Offline Sam
  • Sam I am
Re: 12 years SORN
« Reply #13 on: 08 February 2012, 16:57 »
Or take a breaker bar to the cam pully bolt  :smiley:
Offline Ben Lessani
Re: 12 years SORN
« Reply #14 on: 08 February 2012, 17:49 »
Tut tut, you're not supposed to turn the engine over via the cam pulley - you can cause the belt to snap/skip a tooth. Always turn the engine over via the crank itself (19mm IIRC).
Offline Sam
  • Sam I am
Re: 12 years SORN
« Reply #15 on: 08 February 2012, 17:54 »
Crank pully was what I was on about but was looking at KR heads and cams on egay at the time. My bad and yes its an 19mm  :smiley:
Offline Roverdose
  • So long and thanks for all the fish!
Re: 12 years SORN
« Reply #16 on: 08 February 2012, 21:20 »
i have witnessed a mk2 8v, stood for 10 years. working battery robbed from a mates mk2 , plugged it in checked oil level, gallon of unleaded and badda boom, started on the button first time! Personally before driving it i'd do the cooling system, drain it, refill with the correct ratio of water / coolant 50/50. Then run it up to temperature. Soon as it hits 90 degrees C switch it off then change the oil and filter. I'd also maybe pull the sump off and check the oil pump filter isnt full of conjeeled sh!te. Engine flush and injector cleaner is a good shout and basicly just service it to buggery. It's worth getting a local specialist to look over it for mot. A well trained eye can spot things that others will miss and save you serious wonga! Don't go by the advert go by personal recomendation. if your in cornwall i can recomend ya somebody! Good luck!
Offline The Mighty Elvi
  • I'm better than you today.
Re: 12 years SORN
« Reply #17 on: 08 February 2012, 21:26 »
Engine flush is not a good idea for older engines.  The carbon deposits and crud it removes could foul up the oilways etc..
Offline X4MGS
  • VAG Parts SNOB!!!
Re: 12 years SORN
« Reply #18 on: 08 February 2012, 21:45 »
I've also heard this too...
For More Info Click To See;
Offline twotwofour
Re: 12 years SORN
« Reply #19 on: 08 February 2012, 21:53 »
I have had a bad experience of this and would agree. £700 that engine flush cost
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
