Author Topic: Absolute epic fail.....  (Read 4590 times)
Offline manners
« on: 07 February 2012, 15:07 »
Basically I bought a mk2 oak green 16V gti about a week ago, only driven it to work once or twice and about 35 miles from the bloke I bought it off and now it wont start at all even with leads attached.
It doesnt make a tick over or turning sound just makes a single tone.....kinda like a buzzer sound.
Does anyone have any ideas what this could be, Im meant to be learning how to do all this, hence why I bought a runner.....now its not and im a little out of my depth!
Offline dubber36
Re: Absolute epic fail.....
« Reply #1 on: 07 February 2012, 15:15 »
I sounds as simple as a battery to me. The buzzing sound would be the fuel pump.
Are you using decent jump leads? Does the time clock reset to 0:00 when you try to start it?
Offline Seanl
« Reply #2 on: 07 February 2012, 15:31 »
Buzzing could be ISV. Get a known good battery to start off with as suggested.  :smiley:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 07 February 2012, 15:43 »
Duff Starter motor??
For More Info Click To See;
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #4 on: 07 February 2012, 16:38 »
Calm down Thomas.  Could be something very simple, most likely the battery.
We'll sort it out.  :wink:
If you don't have access to a good battery, have you tried bump starting it?
When you turn the key do you only get the buzz of the fuel pump priming and then a click?
Does the radio, wipers, lights all work at full power?
Do you have a Mulitmeter to test the battery.  (2.99 in the Off Topic Section  :wink:)
We need symptoms. Then it's a process of elimination.
Offline manners
« Reply #5 on: 08 February 2012, 02:24 »
Ill get some fault finding done tomora, there isnt a buzz of the fuel pump at all....it did do that but then went intermitant and then no more.
The buzz is coming from the starter motor I believe!
They were a generic bunch of leads attached to my mates diesel Audi....didnt want to use my car lol Im going to take the positive termial off and connect the jump lead to that and as normal to the neg to bypass the battery draining any power away.
The lights etc are working....well the lights are I didnt check the wipers.
I got advised by someone I work with to connect the neg jump lead to the earth and then with his car running touch the pos of the sterter motor to see if it spins up!!!
Offline JC
  • Back in the North.
« Reply #6 on: 08 February 2012, 07:34 »
I may aswell start the bidding,  £150  :wink:
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
« Reply #7 on: 08 February 2012, 10:33 »
Epic fail???
Thats just the everyday pain of owning a mk2 lol
Offline SoundillusioN
« Reply #8 on: 08 February 2012, 10:55 »
Sounds like a dud solenoid in the starter.  Give it a whack!  :wink:
Offline twotwofour
« Reply #9 on: 08 February 2012, 12:02 »
I had the same on my 8v mk3.
Needed a new starter motor but when i attempted to start it all lights etc went dim. I used multimeter to check power was getting to appropraite points and i concluded a new starter motor.
It had already given tell tale signs. Slow to turn over etc.
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
