Author Topic: quick one k03s turbo info  (Read 1545 times)
Offline daz veedub
  • Operation 1.8t bolf
« on: 06 February 2012, 19:58 »
is the k03-052 of a 180bhp seat leon 1.8 20v turbo a k03s  :undecided:   just want to double check before i commit  :lipsrsealed:
« Last Edit: 06 February 2012, 20:40 by richw911 »
Offline Toby
  • Car - less
Re: quick 1 please
« Reply #1 on: 06 February 2012, 20:09 »
Id have  thourt so tbh, off a 180 bhp
Currently down under
Offline daz veedub
Re: quick 1 please
« Reply #2 on: 06 February 2012, 20:19 »
i think it is mate just want to make sure  :smiley: nice 1
Offline jonrandom
Re: quick 1 please
« Reply #3 on: 06 February 2012, 20:28 »
yes mate it is. Pasted from a audi forum
All the following turbos have the same installation dimensions and
thermodynamical performance. The differences are only in the actuator that
opens the turbine bypass valve:
K03-011 (5303 988 0011) 150 hp, 65 N actuator
K03-026 180 hp, 85 N actuator
K03-035 180 hp, 85 N actuator
K03-044 150 hp, 65 N actuator
K03-045 156 hp (Ibiza Cupra), 85 N actuator with 2 ports
K03-049 150 hp (Sharan/Alhambra), 65 N actuator
The 180 hp versions have an actuator with a higher opening force due to the
higher exhaust gas pressure (which is a consequence of the higher boost
pressure). Otherwise the valve would be pushed open by the exhaust gas
pressure.
The following turbos are a further development (since 2000) and have an
improved and slightly larger compressor while using the same turbine (still
with the same installation dimensions):
K03-052 180 hp, 85 N actuator
K03-053 150 hp, 85 N actuator
K03-058 150 hp/180 hp, 85 N actuator
Re: quick 1 please
« Reply #4 on: 06 February 2012, 20:38 »
Yes it is a k03s mine has the same fitted.
Offline richw911
Offline daz veedub
Re: quick one k03s turbo info
« Reply #6 on: 06 February 2012, 20:41 »
nice 1 guys  :cool:
Offline Toby
  • Car - less
« Reply #7 on: 06 February 2012, 21:00 »
Fitted it yet ?  :grin:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 06 February 2012, 22:37 »
All AUQs to my knowledge came with the K03-052, it should be a silenced version  :smiley:
Offline Chris.
« Reply #9 on: 06 February 2012, 22:42 »
8 turbine blades  = k03s
12 turbine blades = k03 is a common way to tell too
Sure i got that round the right way.
Click For Build Thread
