Author Topic: Windscreen wipers  (Read 1935 times)
Offline javsta
Windscreen wipers
« on: 06 February 2012, 18:07 »
Hey all
hope all is well....I discovered something strange on the motorway today, my driver side windscreen wiper is smashing against the right hand side of the wind shield when fully extended.
Please can anyone suggest why this maybe and how I can put it right? is it as simple as a change off wiper blades will fix the problem??
Thanks in advance
Offline RedHP
Re: Windscreen wipers
« Reply #1 on: 06 February 2012, 18:15 »
Might be an alignment/fitting issue, are they original, if so take back to dealer and let them do it
Red
Mk6 GiT since birth in 2010
YNWA
Offline SRGTD
« Reply #2 on: 06 February 2012, 18:49 »
If you've been driving through falling snow during the past few days and it's built up at the bottom of the screen, the wipers won't be able to sweep fully downwards beyond any accumulated packed-down snow. This may cause the wiper arms to twist round from their usual position on their spindles - i.e. they don't sweep to the bottom of the screen and the driver's side one may sweep upwards too far in the vertical position (hope that makes sense!).
When they're in the 'parked' position, do the sit higher than normal? If so, this would explain why the driver's side one has started hitting the 'A' pillar. Should be a simple adjustment to put them right.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline dubber36
« Reply #3 on: 07 February 2012, 15:19 »
Mine used to hit the A pillar, so I undid the arm retaining nut, pulled the arm off and set it so that it parked a fraction than before. Job done.
The arms are a bugger to get off though, so be carefull not to damage the bonnet when pulling at them.
Offline JonnyG
« Reply #4 on: 07 February 2012, 20:02 »
As above I reckon it's slipped a notch on the spindle and needs adjusting back.
To lift the wiper blade fully off the screen safely, follow the handbook guide (useful for washing the screen too) :-
It's something like this
1. Put the key in the ignition and turn to the start position (the one just before firing up the starter motor  :wink:)
2. Turn the key back to off position (and remove key if you want)
3. Immediately (or fairly quickly) press the windscreen wiper stalk down briefly (as if to do a flick wipe)
4. The wipers should raise and park at the top, allowing them to be hinged away from the screen safely
Current : Seat Cupra Lux, DSG, Magnetic Grey, Sept 2019
Gone :    Golf Mk 7 R, 5dr DSG, Pure White, March 2017
Gone :    Golf Mk 7 R, 5dr DSG, Tornado Red, March 2015
Gone :    Audi RS3, Daytona Grey, 7sp S-Tronic, Sept 2012
Gone :    Golf R, Rising Blue, 5dr DSG Mar 2010
Gone :    Golf R32, DBP, 5dr, DSG, Nov 2008
Gone :    Golf GTi ED30, Mar 2007
Offline Mr_F
« Reply #5 on: 08 February 2012, 19:13 »
Park them and pull them away from the windscreen when it's icy too!  Makes your car look like it's got antennas but does save on ripping them.
61 Plate GTD 5dr, Shadow Blue, 18" Charleston's, Flat Tyre Indicator, Cruise Control, Bi-xenon (With Dynamic Curve), Storage Pack, Winter Pack and RCD 510.
