Author Topic: Portable USB HDD to fit armrest advice required.  (Read 1641 times)
Offline Mr_F
« on: 06 February 2012, 17:23 »
Hi Guys,
I'm looking at doing an offsite / in-car backup of my CD collection and after the most suitable 500gb portable 2.5" HDD around to fit under the centre armrest.
-- What model do you have and how well does it fit?
-- Does it drop to the bottom of the void? WD Passports get wedged!
-- Does the USB connector get jammed or require bending to fit?
If you have a smaller HDD in a range that has a 500gb option I would be interested in it's physical features too!
Once I've got the information I'll go update the Car Audio section with some knowledge.
Kind regards,
Mr F
61 Plate GTD 5dr, Shadow Blue, 18" Charleston's, Flat Tyre Indicator, Cruise Control, Bi-xenon (With Dynamic Curve), Storage Pack, Winter Pack and RCD 510.
Offline RedHP
Re: Portable USB HDD to fit armrest advice required.
« Reply #1 on: 06 February 2012, 18:16 »
Sorry don't use USB, but you should have a cable to connect to USB (like you do for iPod connection) so no bending of USB etc
Red
Mk6 GiT since birth in 2010
YNWA
Offline ajmoir36
« Reply #2 on: 06 February 2012, 21:02 »
I use a western digital passport 500gb and it is slightly tight because of the rubber so what I did was put a loop of selotape up both sides vertically and create a folded tab of selotape to grip it and pull out. There is too much cable but it can be fed down the sides and the cable has a reasonable kink in the top but it works ok
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline Mr_F
« Reply #3 on: 07 February 2012, 10:38 »
Cheers Aj, I borrowed one of those and thought it was a bit tight, but that's certainly enough to put it back in the running!
Any more, come-on there's more than one person with a HDD...
Offline andyr
« Reply #4 on: 07 February 2012, 15:26 »
Sorry don't use a HDD, but a 32G memory USB stick.
Couple of things I found, The head unit does not recognize M4a compression (well my 310 doesn't), it just came up as 'file error', so save your music as MP3 (or WAV perhaps?) and I also had to create a folder called 'music' on the stick and drop everything in there before it would work..... If I Just dropped everything in the root area then only the first alphabetical artist would be recognized  :huh:
Mk VI Black Pearl GTD.... No Frills, replaced a Black Pearl PD150 Bora, which in turn replaced a Dragon Green VR6 which followed a Dusty Mauve MK III 8v Gti.
Offline Nutkins
« Reply #5 on: 07 February 2012, 15:59 »
Don't think you can use WAVs. Which is a shame considering the storage options availible now.
Offline andyr
« Reply #6 on: 07 February 2012, 18:08 »
Yeah, quite possible, but if the manual's checked I'm sure it gives you exactly what it'll read (mine's in the glovee and it's cold out there!)
Offline pumaboat
« Last Edit: 09 February 2012, 15:39 by pumaboat »
