Author Topic: lcr brake setup . much work ?  (Read 832 times)
Offline jonnyturbo
« on: 05 February 2012, 13:52 »
I know that the front brembos require adaptors to fit the mk4 but what size are the rear brakes/calipers on a lcr and what sort of work is required to make them work? Does the lcr run 256 vented on the rears?  Thanks
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: lcr brake setup . much work ?
« Reply #1 on: 05 February 2012, 14:55 »
Yes vented 256. Think it's plug and play bar the splash guards, need changing or grinding off IIRC.
Offline richw911
« Reply #2 on: 05 February 2012, 16:19 »
Yep you have to modify the original splash guards or buy the correct ones that go with the 256mm set up  :smiley:
Offline blade4real2004
  • golf gti with a touch of .:R
« Reply #3 on: 06 February 2012, 11:13 »
its hubs off to change the gards or you cut the lip off your ones you go on there now
k04s | jabba cai | stage 2 (Rtech) | forge 007p | forge boost hose set |forge tip | THS fmic | gen r line kit | bbs ch | TT short shift | R32 vents | full stainless | decat | auto windows | mk5'd boot
need a scan or mod with vagcom & vagtacho PM ME (south wales area)
my build thread - http://uk-mkivs.net/forums/t/236415.aspx?PageIndex=1
