Author Topic: 1z fuel pump timing slipped again  (Read 884 times)
Offline dubpirate
« on: 05 February 2012, 08:40 »
can someone shed some light on whats happening for me
i understand the fuel pump is run by the cambelt
but it has slipped on the fuel pump again  :cry:
so is it siming belt off job again
check pulley on pump
it is a modified 1z running 128bhp
so could the extra power cause this
if i were to take it back to a garage what would i tell them to do and what posrs will i need
cheers dan
Offline CJA321
Re: 1z fuel pump timing slipped again
« Reply #1 on: 05 February 2012, 12:18 »
The same as what wayne said on your post about this like a day ago??! Belt off, check everything for wear etc... as said before could be crank...
not really anything else thats not been said in your last thread...
If it runs fine once started and it just takes a long time to start thats another problem completly  :laugh:
« Reply #2 on: 05 February 2012, 21:29 »
If it is taking ages to start then it sounds like pump timing to me or loss of compression
Offline danny_p
« Reply #3 on: 05 February 2012, 23:46 »
if pump timeing keeps moveing the cranck and cranck pully are likely knackerd  take it off an have a look at the keyway
all the VW's have gone bar 1.
