Author Topic: Temp/MPG fault  (Read 1886 times)
Offline RhosneigrGaz
  • More Doors Crew!
Temp/MPG fault
« on: 04 February 2012, 19:54 »
I hate people posting without searching/researching but i'm a little stuck...
Got car last week, 106,000 miles and seems well looked after.
However its running cold 70-80c, idling like a b!tch 500-2000rpm, engine management light on and 25mpg driving slowly.
Now i'm expecting it to be a MAF or Lamda but have read a thermostat and temp sender will cause low MPG?
Why is this? anyone explain it to me?
Gonna get my own VAG COM check tool thing having read a post tonight on it and see what it throws up!!
'02 3dr Tornado Red Gti 20v Turbo
Offline richw911
Re: Temp/MPG fault
« Reply #1 on: 04 February 2012, 20:11 »
Could be a mix of things but yeah the temp sender could well be gone.
http://www.golfgtiforum.co.uk/index.php?topic=88088.0
When you have the reader you need to scan the car then drive it and see which codes if any reappear
Re: Temp/MPG fault
« Reply #2 on: 04 February 2012, 21:24 »
Sounds like a knackered temp sender.
  • More Doors Crew!
Re: Temp/MPG fault
« Reply #3 on: 04 February 2012, 21:26 »
Appreciate ur help guys
Ordered the VAG COM reader, gonna order the temp sender/stat also, as i plan to keep the car 3-5 yrs its worth doing whatever!!!
Thanks!
Offline richw911
Re: Temp/MPG fault
« Reply #4 on: 04 February 2012, 21:27 »
Thanks!
TBH they are both very common faults and for the price you are wise to replace them  :smiley:
Offline golf-sib
  • Турботазик
Re: Temp/MPG fault
« Reply #5 on: 04 February 2012, 22:52 »
Temp sender is very easy to do, open rad valve up, drain some coolant, I  usually remove airbox  to make it a lot easier to work with and its one clip out, sensor pulls out (collant will poor out when sensor is removed unless you drained some coolant), new sensor in, clip in and wollah
But it does sound like temp sensor
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
  • More Doors Crew!
Re: Temp/MPG fault
« Reply #6 on: 10 February 2012, 15:54 »
Got me fault code reader which lit up like a frikin Xmas Tree!!!!
Cleared the faults and fitted new sensor, still no joy, so gonna do the stat in the week.
Amazing what the fault code reader showed up:
16486 -          Maf - Signal too low - NEW MAF TIME
16684-85-86 - Random Misfires      -  Keep an eye on this
17544 fuel trim bank (add) system to lean , p1136-35-00 - Investigate hose boost leaks
17704 - Error in mapped Cooling system - Hope that green sender and stat sort this
17705 - Pressure drop between turbo and throttle valve - Clean Throttle body and investigate boost leaks
17956 - Boost pressure regulation valve N75 - Check wiring to N75 and maybe replave N75
Plenty to be getting on with but nothing major i hope
Again as i plan to keep it gonna do a full plugs and filter change whilst i'm fidling next week...... FUN N GAMES Eh?
Offline richw911
Re: Temp/MPG fault
« Reply #7 on: 10 February 2012, 16:12 »
17705  :lipsrsealed:
  • More Doors Crew!
Re: Temp/MPG fault
« Reply #8 on: 10 February 2012, 16:14 »
Offline richw911
Re: Temp/MPG fault
« Reply #9 on: 10 February 2012, 16:16 »
17705  :lipsrsealed:
Spill the beans....
Boost leak that is a nightmare to find   :sad: However check the pancake pipe as is prone to leak there. Does it have the standard recirculating valve on it?
