Author Topic: maf troubles  (Read 2294 times)
Offline richw911
Re: maf troubles
« Reply #10 on: 04 February 2012, 17:06 »
Going from a mk3 to a mk4 was meant to be an upgrade :rolleyes:
Upgrade to loads of electrical faults  :cool:
Offline mk3tony
Re: maf troubles
« Reply #11 on: 04 February 2012, 19:25 »
Won't you have to reset engine adaptions if new MAF fitted?? Reset mine when i fitted new MAF to mine.
is it not just a case of fit new one, plug in and off you go?
2001 1.8T AUM - Rtech Spec 1 Custom Map, Catch Can, Cone Filter, 209bhp 237 lb/ft, SuperPro Wishbone and Rear Beam Bushes, Jom Coilovers, 19" BBS CH Reps
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: maf troubles
« Reply #12 on: 04 February 2012, 19:30 »
you can just drive it, the ECU will learn to adapt over a few miles  :wink:
Re: maf troubles
« Reply #13 on: 04 February 2012, 21:29 »
Correct as Wez said it will self learn, just clear all the old codes.
Offline mk3tony
Re: maf troubles
« Reply #14 on: 04 February 2012, 22:36 »
i just plugged it in and it seemed quite laggy, made the boost come in really heavy and didnt like cold mornings. Ever since its been unplugged its been fine! But i'm not risking £120. Just need to try someone elses maf. Bloody snow!
