Author Topic: Radiator has a small leak!  (Read 1688 times)
Offline drivebycar
« on: 03 February 2012, 20:06 »
Have noticed a bit of steam coming from what looks like the side the radiator if the temp guage moves above 1/2 way.
Are there any ways to remedy this short of replacing the radiator? Are products like radweld worth a go or are they just a waste of time?
Car is a 1990 mk1 cabby clipper btw
Thanks
Normal is getting dressed in clothes that you buy for work and driving through traffic in a car that you are still paying for - in order to get to the job you need to pay for the clothes and the car, and the house you leave vacant all day so you can afford to live in it.
Offline todd
Re: Radiator has a small leak!
« Reply #1 on: 03 February 2012, 21:20 »
Don't use any of that bud it's a pain in the arse to clean out just get a new radiator shouldn't be too expensive and should be something you could do yourself
Offline drivebycar
« Reply #2 on: 04 February 2012, 10:41 »
Yeah that's what I thought. Only just flushed the system and topped up with G12 so don't want to have to go through and flush it again. Thanks
Offline njonjocharles2
« Reply #3 on: 05 February 2012, 11:28 »
Many products out there will promise to seal the problem up but you'll get your money's worth if you simply just pop in to your local scrapyard and get a used radiator for a mare 20quid or less and about 15 on labour replacement.
Offline AudiA8Quattro
« Reply #4 on: 07 February 2012, 00:31 »
Radweld works fine, never had a problem with it.
I wouldn't recommend getting a second hand radiator, it could be just as bad, fit a new one if you don't want to seal it, they aren't that expensive.
Offline danny_p
« Reply #5 on: 07 February 2012, 20:23 »
just get a new pattern radiator.
getting them off ebay or a braker just isnt worth it due to the bother / cost ratio
all the VW's have gone bar 1.
