Author Topic: scanned my car this is what it says  (Read 932 times)
Offline rench
« on: 01 February 2012, 22:49 »
Connection turbocharger - throttle valve pressure hose
Long Term Fuel Trim mult.,Bank1 System too Rich
Long Term Fuel Trim Add.Fuel,Bank1 System too Rich
Power Supply (B+) Terminal 30 Low Voltage
Clutch Vacuum Vent Valve Switch Incorrect signal
and 17608 but carnt find this code
Offline barrym381
Re: scanned my car this is what it says
« Reply #1 on: 02 February 2012, 00:10 »
If you've bypassed the N249 you'll always get a 17608 fault as it's not working. The code will clear if you get a resistor to fool the car into thinking it's still operating :smiley:
jockgti
« Reply #2 on: 02 February 2012, 05:40 »
The power supply one is usually to do with having battery off at some point,clear that and it should stay cleared
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 02 February 2012, 07:47 »
As above, clear them all and see what comes back. You don't know how long they've been on there
