Author Topic: front engine mount  (Read 3497 times)
Offline Steve!
front engine mount
« on: 18 May 2005, 07:07 »
Hi ive got a corrado g6o and the front engine mount has bust, ive been told that i could use a front engine mount from a mk2 gti, is this true?
                            cheers steve
Offline Gambit
Re: front engine mount
« Reply #1 on: 18 May 2005, 09:39 »
get a solid rubber mount from a 2.0 16v corrado from EuroCarParts
Offline ...joe
« Reply #2 on: 18 May 2005, 10:18 »
it will indeed but it'd be worth getting a heavy duty one as its in a g60. i use one of these:
which was designed for a g60 corrado. i can get you one from the guy who makes them if you want?
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline ...joe
« Reply #3 on: 18 May 2005, 10:26 »
i've answerd this in your other post saying about a solid engine mount designed for the g60 corrado if your interested?
Offline Tornado-red_gti
« Reply #4 on: 18 May 2005, 12:38 »
The frony engine mount is on it's way out on my MK2 golf. Can I use a solid rubber one?
Offline Gambit
« Reply #5 on: 18 May 2005, 13:18 »
yes you can also use the corrado 2.0 solid rubber mount
Offline Gambit
« Reply #6 on: 18 May 2005, 13:29 »
EuroCarParts actually list the same part numbers for mk2 16v & corrado 16v & corrado G60
Part Nums
33740250
33740251
one of these is the front hydro mount, and the other the front solid rubber mount. just make sure you ask which is which!
« Reply #7 on: 18 May 2005, 15:00 »
CHEERS GAMBIT  :cool:
Offline mr.brown
« Reply #8 on: 18 May 2005, 15:06 »
Or I can get you one of these babies for £50 inc p&p.
Offline Gambit
« Reply #9 on: 18 May 2005, 15:38 »
a solid mount will tranfer the vibration/pulling force onto the front crossmember bushes, so replace them at the same time if your gonna fit one of these. they are meant to be a good job though!
