Author Topic: best place to mount catch can?  (Read 3100 times)
Offline rench
« on: 01 February 2012, 19:01 »
wares best place to mount catch can, at the min mines just self tappered into front plastic near light.
pics would be good  cheers
Offline jonrandom
Re: best place to mount catch can?
« Reply #1 on: 01 February 2012, 19:15 »
Wherever it will fit  :grin:
Heres mine
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
« Reply #2 on: 01 February 2012, 19:26 »
Heres mine made a bracket up at work.
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline rench
« Reply #3 on: 01 February 2012, 19:39 »
What hoose is that?
Offline symsymma
« Reply #4 on: 01 February 2012, 20:10 »
Mines 19mm i/d oil resistant hose with quite a chunky wall thickness.
Offline rench
« Reply #5 on: 01 February 2012, 20:16 »
Got a link? The stuff I've gots to soft
Offline symsymma
« Reply #6 on: 01 February 2012, 20:23 »
Not got a link got it from hosequip i think its called google that.what size inlets and outlets you got?
Offline rench
« Reply #7 on: 01 February 2012, 20:27 »
Booth 19mm I've just got silicone vacuum hoose at the min
Offline symsymma
« Reply #8 on: 01 February 2012, 20:37 »
Urs would break down after time aswell unless its oil resistant.just dug out my reciept the phone number for hosequip is 01206 231103 think it was about £10 a meter.think the main company name is sirus uk. :smiley:
Offline symsymma
« Reply #9 on: 01 February 2012, 20:41 »
Used just under 2 meters on my install,you want nice curves to,no sharp bends on ur hose.if u need a sharp bend use an elbow piece you can get all the bits from hosequip if req.
