Author Topic: Coolant Leak  (Read 1509 times)
Offline Dalo Harkin
Coolant Leak
« on: 01 February 2012, 13:23 »
Hi all,
I have a very random coolant leak, checked all the hoses etc and there doesnt appear to be anything that appears obvious to me.
Its intermittent too, some days no leak others (like today must be about 50ml worth on the floor)
any clues / ideas where to look.
It has  G12 or whatever it is so its Red and obvious when it leaks but there are no signs of it on the engine / gearbox or anything
Re: Coolant Leak
« Reply #1 on: 01 February 2012, 13:41 »
Best bet would be to get the system pressure tested, that will soon show any leaks.
Offline Dalo Harkin
Re: Coolant Leak
« Reply #2 on: 01 February 2012, 14:08 »
popped it in a garage and they reckon its the water pump, only had a new timing belt done, not too long ago.....
Water pump is a pain in the arse to do isnt it
Offline tokemk4gti.t
  • 2001 gti turbo :-)
Re: Coolant Leak
« Reply #3 on: 01 February 2012, 14:13 »
might sound daft but u checked the tap at bottom of radiators properly closed?
Offline Dalo Harkin
Re: Coolant Leak
« Reply #4 on: 01 February 2012, 16:35 »
Yeah, its coming from down the side of the block though  :cry:
jockgti
Re: Coolant Leak
« Reply #5 on: 01 February 2012, 20:28 »
i had a leak from the right side of the block but it was this plastic pipe,it split along the plastic seam,only leaked under pressure or after a spirited drive
Offline Dalo Harkin
Re: Coolant Leak
« Reply #6 on: 02 February 2012, 08:35 »
I'll check that as it does seem to be under load
Offline gavgtiturbo
Re: Coolant Leak
« Reply #7 on: 02 February 2012, 19:06 »
Pull the top hose off the expansion tank,unscrew the top of it where you fill up with coolent and hold it over the hole where the lid was... Get someone to start the car and rev it..When you hold the revs there should be a steady flow of water going back in to the tank from the top hose your holding. (about the same amount of water flowing through a straw). If this isnt happening your water pumps had it  :wink:.
Mine leaked every so often and it turned out to be the little o seal on the bottom of the temp sensor.
jockgti
Re: Coolant Leak
« Reply #8 on: 04 February 2012, 20:13 »
found out what the problem is yet?
Offline Dalo Harkin
Re: Coolant Leak
« Reply #9 on: 07 February 2012, 08:40 »
Not yet no, I am going to try the suggestion above that gavgtiturbo suggested...
BUT I have ordered the plastic part that you said was cracked just incase (VW dont stock these anywhere in the UK apparently, so I have had to order it from them, should be here this week)
and I will look over weekend.
I just hope its not the water pump  :cry:
