Author Topic: 4 stud 5 stud  (Read 3077 times)
Offline Nathan...
4 stud 5 stud
« on: 31 January 2012, 20:44 »
I'm sure this has been covered a million and one times but can someone give me a definitive guide in converting to 5 stud on my lovely mk2? Thanks :smiley:
Offline Lewy
Re: 4 stud 5 stud
« Reply #1 on: 31 January 2012, 21:32 »
Go wide track with mk3 hubs, wishbones and track rods on the front, and a mk3 rear axle as its about 10-15mm wider than a mk2.
Mk2 narrow track is a b@stard to do, but the rear is just simply discs and hubs.
Offline Nathan...
Re: 4 stud 5 stud
« Reply #2 on: 31 January 2012, 21:54 »
OK thanks for that, so narrow track is narrower than I currently have?
I'm looking for a bit of dish when it comes to wheels, is a wider track going to affect that in any way when it comes to being lowered?
Offline Lewy
Re: 4 stud 5 stud
« Reply #3 on: 31 January 2012, 22:31 »
No no, narrow track is what you've got already, fitting the Mk3 components will give it a wider track, hence the term.
What kind of wheels are you looking at, or is it a set of 5x100's that have tickled your fancy?
Offline Nathan...
Re: 4 stud 5 stud
« Reply #4 on: 31 January 2012, 22:55 »
nothing special, just these
..... to start with :grin:
 I assume they're 5x100  :grin:
thanks for the gen, I am new to the VAG game!
And if I wanted to fit PAS as well, what would the repercussions be? mk2 or mk3 components for that?
Offline Lewy
Re: 4 stud 5 stud
« Reply #5 on: 31 January 2012, 23:21 »
Those wheels are early A4 items, so they'll be 5x112 I think, and god knows why you would want to fit them  :sick:  .
Retro-fitting PAS isn't too bad a job, but it all depends on your spanner skills and what car you want to fit it to.  Also Mk2 items from a scrapped GTi would be your best bet.
Re: 4 stud 5 stud
« Reply #6 on: 01 February 2012, 00:03 »
They are 100% 5x112 and horrid tbh  :smiley:
Offline mad4vws
Re: 4 stud 5 stud
« Reply #7 on: 02 February 2012, 19:06 »
got complete set up if you require from mk3 gti to convertfrom 4 stud to 5 stud may also have a set of 5 stud alloys to if you want bud .
pm me or give us a call number is at the bottom of each post . :cool: :wink:  :smiley:
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline Nathan...
Re: 4 stud 5 stud
« Reply #8 on: 17 June 2012, 21:04 »
Christ been ages since i last posted. Alright those wheels are pretty rough, but better than the steels it currently doesn't run on.  :grin: I'm just about to prepare to start buying parts, and it should be moving to its new home soon.
It needs all new brakes as they are all seized on now :rolleyes: So I'm thinking either 5-stud it or all new 4-stud and go for rear discs instead. Is it advisable to fit an uprated master cylinder, and can i fit a servo in there too?
Don't suppose you still have any of these parts do you?
My Spanner skills aren't too shabby, I'm pretty confident with one actually. I've had a good look about on eBay but they all seem to go for quite a bit!
