Author Topic: vento front end swap  (Read 3821 times)
Offline josh_vr6
« on: 31 January 2012, 19:25 »
not sure if im posting in the right section here??...
just got my first golf (vr6) and already thinking of a front end swap and was wondering if i can fit a 'vr6' badge on the vento grill??
cheers
Offline Lewy
Re: vento front end swap
« Reply #1 on: 31 January 2012, 19:50 »
Moved it for you mate, as the barrage boys are over here.
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 31 January 2012, 19:56 »
you can fit any badge, they just clip on (although you may snap a clip or two when removing from the golf!! I just add some body trim tape for extra security)
Offline Edwh0re
« Reply #3 on: 01 February 2012, 05:50 »
Depends on the grille.
When I first got my Vento front, it had a horrific debadged late grille, and I put the GTI grille badge on it in an attempt to make it look less horrific.
When I got my facelift and then my early grille.... The space between the slats was too large for the GTI badge to clip in (not that I wanted to), and the early grille too small.
Offline Deano2711
  • 1992 VR6
« Reply #4 on: 01 February 2012, 07:12 »
Mine fitted perfect as per sig picture.
Offline Edwh0re
« Reply #5 on: 01 February 2012, 15:31 »
Aye, thats a late style grille, same style as the one which my GTi badge fitted.
« Reply #6 on: 01 February 2012, 15:47 »
Vento and debadged grilles looks better without the GTI badges
Offline Edwh0re
« Reply #7 on: 01 February 2012, 17:30 »
That particular debadged grille would have looked better in the bin   :grin:
Swapped it directly for a facelift badged one with someone after 2 days of Vento front ownership, so was well in the end...
Offline Junior74
« Reply #8 on: 01 February 2012, 20:04 »
Jammy b@st#rd!!!!!!  :smiley:
Offline stainesy
« Reply #9 on: 01 February 2012, 20:49 »
Gti badge works on a badged vento grill. And debadged vento grill only works totaly debadged I recon.
