Golf mk4
Wazzzer
can you help tried everything
Topic: can you help tried everything (Read 1866 times)
richw911
10k hero
The Linkmeister and an OEM Freak.
Re: can you help tried everything
Reply #10 on:
31 January 2012, 19:28 »
Yeah let us know
m4nesh
GTI forum regular
Reply #11 on:
02 February 2012, 10:26 »
Hi guys
Can you help?
Took it to the dealer they said all is fine and the harsh ride is down the the shocks that I have changed. I changed them to Bilstein B4 shocks (gas) and the technician I took the car out with said it seems as though the shocks are very hard hence the hard ride. So my question is seeing as the ride is so intolerably harsh should I change to standard VW ones and will they be that much different?
Also will the powerflex rear beam bushes I had installed exaggerate the issue also?
Your response would be greatly received as car is in the stealers getting some random warranty work on coils (which I knew nothing about) so if you think it is worth changing the shocks I guess I'll call and ask them to do the job.
navmk4gti
Forum addict
Reply #12 on:
02 February 2012, 11:19 »
Powerflex bushes are hard as fook.. So they would be part of it and i think the shocks just added the finishing touch To your hard ride.. I ha powerflex bushes in my dogbone mount changed back to standard eventually i could not take the harshness. espicially if you live somewhere full of humps and pot holes
Y did you not go for tt or vrs bushes?
Website:
https://www.theonestopledshop.com/
m4nesh
GTI forum regular
Reply #13 on:
02 February 2012, 11:28 »
I also have a bmw 325 sports coupe also and was reeally pleased with the powerflex bushes on them, hence why I tried them on the 1.8t
guess I should of checked..
Just googled bilstein shocks and they are notoriously hard as mentioned by a few people
richw911
10k hero
Reply #14 on:
02 February 2012, 15:11 »
The coil issue is a recall on the coilpacks that can be faulty on later 1.8T's all for free
m4nesh
GTI forum regular
Reply #15 on:
02 February 2012, 18:10 »
bought some oem boge rear shocks will report back and let you know if this solves the problem, cheers.
Golf mk4
Wazzzer
