Author Topic: Quick headlight q's  (Read 2575 times)
Offline navmk4gti
Quick headlight q's
« on: 30 January 2012, 22:33 »
Are mk4 headlight lens glass or plastic?? Also can you get lens on its own... Looking do joey mod  :smiley:
Offline daz veedub
  • Operation 1.8t bolf
Re: Quick headlight q's
« Reply #1 on: 30 January 2012, 22:34 »
think there glass mate
Offline navmk4gti
« Reply #2 on: 30 January 2012, 22:36 »
Damn then will be right pain using heat gun get em off without breaking them. I hope can get just lens for em cant seem find em anywhere tho  :undecided:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Offline navmk4gti
« Reply #4 on: 30 January 2012, 22:42 »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 30 January 2012, 22:59 »
if you want them the same as the anni lights then use gloss black. Make sure you take out the surround inside and give it a good going over with some 800 grade paper then spray it with some plastic primer. Spray the whole of the surround top and bottom, if you miss any chances are you'll see it through the lens once it's back together. Are yuo looking at spraying the parts around the reflectors as well or just the surround like the anni lights?
Offline navmk4gti
« Reply #6 on: 30 January 2012, 23:04 »
No planing spray all off it inside bud.. Right so plastic primer it and then gloss black spray should do it will need laquer too  :wink:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 30 January 2012, 23:16 »
I've never bothered with lacquer. Be careful masking up the reflectors, get yourself some low tack masking tape to go on them first to stop it pulling the chrome off, then use something waterproof over that as the black will find a way through...
Offline navmk4gti
« Reply #8 on: 30 January 2012, 23:21 »
Koolio i had a how to somewhere how spray and what mask somewhere cant find it  :angry: so ill have to mask the reflectors off i see some guys spray that too whole headlight completely black inside :undecided:
Offline iansabf
« Reply #9 on: 31 January 2012, 10:25 »
Let me know how you get on with your lights. I really wanna do mine but slightly dubious of the quality for the replacement lenses. I've read somewhere you can't get the lenses off oe mk4 headlights without smashing them off!? So have been reluctant to even touch my lights  :undecided:
