Author Topic: More suspension issues.  (Read 1445 times)
Offline nightroamer
  • Mk3 16v
« on: 30 January 2012, 19:54 »
Hi guys, in the last few days I've noticed some weird noises from the front of my car. first off the front off side has developed a metal knoking over bumps, like something's loose  :huh:
Now the front off side is doing something similar.
I'm fairly sure I can feel play in both wheels if I pull the top of the wheel back and forth.if I bash my tire with my palm the nearside sounds loose, like metal clanging  :rolleyes:
Don't think it's wheel bearings as I've felt that before.
Sorry for terrible descriptions....
Oh also when I brake there is an initial clunk and slight pedal movement.
What should I look for? Any likely candidates?
Offline Screech16v
  • MK3 20vt AGU
Re: More suspension issues.
« Reply #1 on: 30 January 2012, 20:00 »
Top mounts ?
Offline nightroamer
  • Mk3 16v
« Reply #2 on: 30 January 2012, 20:07 »
How do I check these?
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 30 January 2012, 20:22 »
Jack the car up ,grab the top of the strut at the top see if you can feel for any movement.Or get a bar between the floor and tyre a leaver it up and down slighty whilst checking for play .
« Last Edit: 30 January 2012, 20:25 by Screech16v »
Offline nightroamer
  • Mk3 16v
« Reply #4 on: 30 January 2012, 20:37 »
Cool, anything else I should check whilst I jack it up as I'll have to borrow a jack off a mate.
How much work is involved in renewing the bushes and bearings etc to refurb the whole front running gear.
Offline Screech16v
  • MK3 20vt AGU
« Reply #5 on: 30 January 2012, 20:53 »
Yeah ,trackrods,cv gaitors,steering rack gaitors,wheel bearings,control arm bushes,ball joints, arb bushes.Not masses of work mainly just spanners,you can get new arms with the bushes allready fitted or can have a go at buying the bushes separatly and fitting them into the old arms,bearings wise you could whip the hubs off and get a local garage to fit them for beer tokens,thats if they need doing anyway,ive done them before with a vice ,hammer and large sockets all depends on how compitant you are :smiley:
« Last Edit: 30 January 2012, 20:57 by Screech16v »
Offline nightroamer
  • Mk3 16v
« Reply #6 on: 03 February 2012, 19:21 »
Thanks for all the replies guys. Borrowing a jack tomorrow so I can have a look at what's going on down there.
Has anyone got any pics of the front setup? Few labels and circles drawn would be amazing.
Offline Leon27
« Reply #7 on: 03 February 2012, 19:53 »
Crude but might help...
http://www.ppcgb.com/uploads/images/product/PowerFlex_bushes/VolkswagenGolfMk3%281992-1998%29.jpg
Sound like top mounts as said already but also check number 2 as well - front wishbone bushes, could be the case that both mounts have failed
Offline Seanl
« Reply #8 on: 03 February 2012, 20:10 »
Or could just be loose wheel nuts.  :huh:
Offline nightroamer
  • Mk3 16v
« Reply #9 on: 04 February 2012, 11:09 »
Thanks guys, gonna have a look now  :wink:
