Author Topic: Fitting a radiator  (Read 827 times)
Offline Povey
Fitting a radiator
« on: 30 January 2012, 12:52 »
Hi everyone, I've blown my radiator well it went during the MOt the other week and just by looking  quickly its a bit of a mission to replace? Do I need to take the front bumper off to get to the securing bolts for the shroud? I can't see how the rad is held other than that?
And one last silly question, how's best to fill the system once all the new stuff is on because my 190e was a mission and a half to bleed! Any ideas?
Thanks
Pove
Offline Seanl
Re: Fitting a radiator
« Reply #1 on: 30 January 2012, 13:50 »
Think there are guides in the maintenance and info section for both mate. Yeah anyway, you need to take the bumper off. Its very straightforward actually, but a bit of a pig if you have aircon as the a/c rad sits in front of it, and trying to manouvre it round that is a PITA! Bleeding is just filling slowly, running the engine whilst massaging hoses and revving to 3k rpm every other minute for 30 seconds with expansion tank cap off. Does take a while though.  :smiley:
Offline 67buggers
« Reply #2 on: 30 January 2012, 20:02 »
I did mine a week ago, took about 2hours, bumper grill and slam panel off which was well easy.....only needed a 10mm and a 13mm ratchet . Then it just un bolts swap it out then put it back together. I'm a complete fist when it comes to mechanics but I managed it, also swapped the fan sensor and thermostat cost about £70 from gsf
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
Offline Povey
« Reply #3 on: 31 January 2012, 08:18 »
Sweet thanks guys I'm guna attack it at the weekend I have a GTI rad and fans so I'm going to replace the shroud to for the twin fans, I'll let you k ow how I get on ;-)
