Author Topic: Pulley noise...  (Read 2751 times)
Offline bunj
  • www.bunjair.com
Pulley noise...
« on: 30 January 2012, 08:16 »
Last couple of days noticed a whine/squeal coming from one of my pulleys I assume.  Also it seems the air con has stopped working at the same time.  Are the pumps prone for failure? It sounded to me though that the noise was higher up ie cam pulleys???
Any help mucho appreciated, Bunj.
MK4 GTi 1.8T, Black magic, stage one Jabba, Forge Split, filter, sportex race pipe, lowered 25mm.
PS3 network: raebuns
Offline myles841
Re: Pulley noise...
« Reply #1 on: 30 January 2012, 08:25 »
Im getting the same noise, seems to me its more to the front of the engine like alternator :/ Revs dont seem to change the noise either you can just hear it on idle
Offline bunj
  • www.bunjair.com
Re: Pulley noise...
« Reply #2 on: 30 January 2012, 08:28 »
This morning it sounded like a supercharger, definatley getting wosre   :cry:
Changes with engine revs also.
Offline dam088888
Re: Pulley noise...
« Reply #3 on: 30 January 2012, 10:44 »
I have an alternator if any one needs one 90 amp one
2000 agu 1.8t lowered 55mm,cream mirrors and wheels,stage 1 map, forge 007p,
Offline Granta Gti
Re: Pulley noise...
« Reply #4 on: 30 January 2012, 11:25 »
I had the same problem last week. Spray some WD40 and see if it stops or a bit, to diagnose if it is the fan belt/pulley. It turned out the bearing on the tensioner pulley was shot! Mine had been standing for 3 weeks so I think with a bit of water ingress and freezing the bearing gave up. Got a new tensioner for £25 :)
Offline bunj
  • www.bunjair.com
Re: Pulley noise...
« Reply #5 on: 30 January 2012, 13:31 »
All sorted, turned out a small piece of bracket had moved on to a pulley and was causing the noise.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Pulley noise...
« Reply #6 on: 30 January 2012, 18:25 »
if your air con doesn't work get it checked out, could either be low on gas, a leak or the compressor gone pop
Offline myles841
Re: Pulley noise...
« Reply #7 on: 30 January 2012, 21:14 »
Bunj where abouts was this bracket mate as i might have a look at the weekend as mines doing my head in
cheers
Offline bunj
  • www.bunjair.com
Re: Pulley noise...
« Reply #8 on: 31 January 2012, 09:16 »
Sorry I meant to say but was in a rush yesterday.  We decided the noise was definatley from the timing belt side rather than aux belt.
Started to remove the top cam pulley cover (plastic)only got it lifted an inch or so and noticed on the side of the cambelt tensioner there was a small bracket with a sharp pointed end which had somehow moved into the edge of the pulley. If your standing at the front of the car looking at the engine the bracket is between the innerwing and the tensioner.  Managed to push it out of the way with a large flat head, job done.
As for the air con, tested it and it was fine??? maybe the compressor is getting lazy.
Managed to adjust my handbrake cable up also...result.
