Author Topic: Spacers????? Help!!  (Read 1119 times)
Offline bigmarky
Spacers????? Help!!
« on: 29 January 2012, 23:02 »
Right since I'm new to the whole Dub scene, I'm about to get a Mk 4 Golf and am interested in sticking some spacers on to make the wide euro look, is this as easy as buying and fitting spacers or is it a bigger job and what spacer sizes are best to get ???
Tornado Red, 99 AGU, full milltek, K & N, forge007p, 18\" A8 in custom Matt Black with Anthracite inserts, Custom remap, 22psi boost, HID\'s, full led\'s, bodykit.
Offline benvictors
  • bgk Tuning - coming soon!!!
Re: Spacers????? Help!!
« Reply #1 on: 29 January 2012, 23:25 »
Dont get the cheap sh!tty ones from Halfrauds or Sgt Bilko's Motosave
You want hub centric ones and if you going more than 5mm per side you will need longer wheel bolts
Offline bigmarky
« Reply #2 on: 29 January 2012, 23:55 »
So basically as long as I get longer bolts and good spacers I'm sound?? Any recommendations on spacer width without fouling any part of the car?
« Reply #3 on: 30 January 2012, 00:01 »
All depends on the wheels you have or are planning on getting plus ride height etc.
« Last Edit: 30 January 2012, 00:06 by Wayne »
Offline benvictors
« Reply #4 on: 30 January 2012, 00:04 »
All depends on wheel size/offset, tyre profile/width, how low you are running and the overall look your after.
Offline tweed
« Reply #5 on: 30 January 2012, 07:11 »
And you won't get hubcentric below 10mm
Offline daz veedub
  • Operation 1.8t bolf
« Reply #6 on: 30 January 2012, 10:12 »
i got 20mm hubcentric 1s off ebay £50 odd quid which comes with the bolts  :wink: :smiley:
