Author Topic: volksbits crystal ind  (Read 2290 times)
Offline GolfGL
« on: 18 May 2005, 21:12 »
just got my crystal indicator and dummy fog set from volksbits. the dummy fog fitted straight away and so i went to push in the indicator section and the spring piece doesnt seem to clip in. am i doing something wrong as i gave it some pushing and even tried to reshape the clip but with no luck. anyone else had this problem or got a solution? cheers
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline Dizzie
  • Make friends with your fast
Re: volksbits crystal ind
« Reply #1 on: 19 May 2005, 09:34 »
big bumper indicators?
I had to wrap a bit of tape round the inner tab which secured it nicely.
Offline GolfGL
« Reply #2 on: 19 May 2005, 11:31 »
oops left that out there for a mk3 and no matter how much force they will not clip in
Offline Nickyb
« Reply #3 on: 19 May 2005, 13:33 »
Did mine last night and encountered the same problem as you.
Fit the fog light first, then you need to slide a very small flat headed screw driver (such as a watch makers) in between the fog and the clip and force the clip to sit behind the fog light.
Be patiant took me about 5 mins a corner, but yes it is a bit of a b!tch.
Offline GolfGL
« Reply #4 on: 19 May 2005, 19:51 »
looks like a gave up a bit to early then. mate recommended a kitchen knife and hopefully get it done when the rain stops. cheers for the input guys.
Offline GolfGL
« Reply #5 on: 20 May 2005, 16:17 »
so i gave it another go and amazingly i got one side in :smiley:. then the second one had the spring clip snap :cry: i am not having a good day, but atleast the guy at volksbits was helpful and sounds like theyl send me out a replacement.
