Author Topic: Tyre pressure for 225/40/18?  (Read 2219 times)
Offline Paul81
  • 2002 GTI Turbo
« on: 29 January 2012, 21:20 »
As the title says guys.
Can anyone help?
Mods - Tinted windows, Mk8 Polo aerial, BBS RS2 alloys, -40mm Koni springs, Bilstein b4 shocks, VRS steering wheel, anni roof spoiler, R32 front bumper, rear anni valance, R32 side skirts.
Offline richw911
« Last Edit: 29 January 2012, 21:26 by richw911 »
Offline Steve_PD
Re: Tyre pressure for 225/40/18?
« Reply #2 on: 29 January 2012, 21:23 »
I run 32psi all round
Offline mcgee9t2
« Reply #3 on: 29 January 2012, 21:24 »
is it not written on the tyre?
« Reply #4 on: 29 January 2012, 21:40 »
Standard pressures is all I have ever used.
Offline stevelfc
« Reply #5 on: 29 January 2012, 22:10 »
32 front
30 rear
Offline tshirt2k
  • Been there...Done that...
« Reply #6 on: 29 January 2012, 22:14 »
As the profile goes lower you should increase the pressure. So it should be higher than standard big sidewall tyres.
Mk3 ABF 16VT Megasquirt V3
Offline james2
  • No scammers please.
« Reply #7 on: 30 January 2012, 00:06 »
31 psi is fine all round ,back can be a bit less(29).Tractor tyres are the same. It take 100psi to pop some beads in on cars tyres. Brother works at tyre centre. :wink: more wieght you take add more psi  :wink:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline tshirt2k
« Reply #8 on: 30 January 2012, 10:22 »
It doesn't matter who works in a tyre place, most put a average pressure in. It's to do with loadings and weight on the tyre.
Why would a 205/50 on a mk3 be 32 front 29 rear. And a 195/50 is 38 front 35 rear?
Obviously these are higher if vehicle is loaded.
And that info is from the petrol flap of a 16v. Cars with different weights would be different.
I'd suggest looking at manufacture recommended pressures and adjust according to the tyre.
Offline tshirt2k
« Reply #9 on: 30 January 2012, 12:47 »
i run 34 front 36 rear
I would have thought it should be the other way round. Unless you have alot of weight in the back.
Pressures should be set to the load rating requirement of the tyre.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=194
