Golf mk4
Wazzzer
brake warning light how to turn off
Topic: brake warning light how to turn off (Read 872 times)
reidy22
29 January 2012, 17:16 »
basically disconnected battery as i was doing some welding on my golf turbo put it back together and started it now the yellow brake warning light doesnt go out and says check brake pads now everything is new is there any way to turn it off ie vagcom or can i pull the bulb from behind it??thank ya
another thing how do i start a project thread lol i cant seem to find the start thread button on here >??
Chris.
Re: brake warning light how to turn off
29 January 2012, 17:20 »
Code it out with vagcom or bridge a wire between the 2 connections on the plug. Im fairly sure (not 100%) that is the way to do it if you cant code it out. Its a useless feature IMHO as 1/2 the pad is still there!
Click For Build Thread
248bhp 278lbft R - Tech Powered 1.8T!! - Gone but NOT forgotton
richw911
10k hero
The Linkmeister and an OEM Freak.
29 January 2012, 17:24 »
Check the wires in the plugs
PM jv or topher for a Project thread
reidy22
29 January 2012, 17:41 »
ok guys cheers can i just remove the bulbs from the back of clusters ??cause am not 100percent sure which sensor it is or are they on all four brakes
Chris.
29 January 2012, 17:47 »
Its only on front passenger for the wear.
Removing bulb will probably cause more issues.
reidy22
29 January 2012, 17:51 »
ahright thanks then ave probably knocked it when i was fitting the suspension cheers mate
Golf mk4
Wazzzer
