Author Topic: Rear heated window  (Read 1170 times)
Offline spall12
Rear heated window
« on: 29 January 2012, 13:33 »
Right guys help please
My rear heated window stoped working a few months back and ive only just got round to trying to sort it out.
I no ever one says check the wires in the boot which i have just done the only break was on the passanger side in a thick white wire which i have just joined back together and it has made no difference.
The rear heated window button does light up red when i switch the head lights on but if you press the button it does not go orange, I have checked the fuse and its on that also took the button out and tried pluging it back in still made no difference
Do all signs now point to the switch on the dash its self ?
Offline richw911
Re: Rear heated window
« Reply #1 on: 29 January 2012, 15:52 »
Change the fuse any way  :wink: Is there power to the rear window when the switch is on?
« Last Edit: 29 January 2012, 17:25 by richw911 »
Offline tokemk4gti.t
  • 2001 gti turbo :-)
« Reply #2 on: 29 January 2012, 17:18 »
its jus a switch test it with a multi meter on ohms.. take the switch back out wen off remove wires should be o.l reading .. wen on should have continuity reading i.e about an ohm plus ure probe reading... if its still o.l wen on the switch is broke! or if u like test voltage in with with wires on.. go from a ground one side should have voltage.. otherside not.. turn switch on should be voltage on both terminals.if either or both of those checks are ok switch is sound.
Offline johnthegooner
« Reply #3 on: 29 January 2012, 17:41 »
Hi
I had the same problem on my Mk4 GTI and it was  the large brown wire on the drivers side.   :smiley:
Offline spall12
« Reply #4 on: 31 January 2012, 06:06 »
john was that on the passanger or drivers side in the boot ?
Offline spall12
« Reply #5 on: 05 February 2012, 10:54 »
guys ive just changed the switch and its still the same !
ive checked the fuse and thats also fine
Does that mean its got to be a broken wire some where ?
Offline spall12
« Reply #6 on: 05 February 2012, 10:58 »
imgoing to change the fuse see if that works any one know what nuber it is ?
when i turn my head lights on the button glows up red but when i switch the switch on it just stays red it does not go orange
