Author Topic: Removing climatronic  (Read 913 times)
Offline funkyfive
« on: 28 January 2012, 22:35 »
Hi all,
I have recently gone 1.8t and need to remove the old climatronic in the dash and too standard. Does anyone know if this is fairly simple? Can it be done as I really dont want it.
Re: Removing climatronic
« Reply #1 on: 28 January 2012, 23:51 »
Removing it is easy but switching back to the 3 dial set up is not so easy, I believe the heater assembly is different
Offline funkyfive
« Reply #2 on: 01 February 2012, 20:50 »
Cheers Wayne, does that also mean that the 3 dial A/C would not work?
« Reply #3 on: 01 February 2012, 20:52 »
I believe to get it fitted you will need to change the heater assembly as it is all different
