Author Topic: Wiring for boost gauge  (Read 1116 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
« on: 28 January 2012, 14:09 »
Hi all,
I have an electronically controlled boost gauge, have managed to plumb in all the vacuum line, I hope! Now I am stuck as to where the wires connect to, I have read about tapping into the dimmer switch, using the grey and blue wire, then the other one find a suitable earth. Is this correct?
If so is the type of connector that I am after for splicing it to the grey and blue wire
Please help...I think it may rain soon  :undecided:
« Last Edit: 28 January 2012, 14:11 by scarr89 »
Offline Darksider1.8T
Re: Wiring for boost gauge
« Reply #1 on: 28 January 2012, 14:28 »
yes mate your correct
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 28 January 2012, 14:58 »
You can use the dimmer switch or the same blue/grey wire on the headlight plug behind the switch. Stick a ring terminal on the end of the earth wire and use one of the bolts next to the fuse box
Offline scarr89
« Reply #3 on: 28 January 2012, 17:38 »
Think I got it all working  :smiley:
CHeers
