Author Topic: anyone in kent who can smoke test/pressure test/fix my car  (Read 1031 times)
Offline mk3tony
Been having the 17544 p1136 bank 1 code and I know its not maf as its brand new genuine from stealers. Dont think it can be pcv as have catch can, I know I have a boost pipe loose so am ordering a 5 piece kit. Just need to know if its just this boost pipe thats throwing it?
2001 1.8T AUM - Rtech Spec 1 Custom Map, Catch Can, Cone Filter, 209bhp 237 lb/ft, SuperPro Wishbone and Rear Beam Bushes, Jom Coilovers, 19" BBS CH Reps
Offline tshirt2k
  • Been there...Done that...
Re: anyone in kent who can smoke test/pressure test/fix my car
« Reply #1 on: 28 January 2012, 13:06 »
Could be anything below. So sort out all your leaks
17544/P1136/004406 - Fuel Trim: Bank 1 (Add): System too Lean
Possible Solutions
    Check Mass Air Flow (MAF) Sensor
    Check Fuel Pressure Regulator
    Check Fuel Pump
    Check Intake/Exhaust System for Leaks
    Check Secondary Air Injection for Leaks
    Check Vacuum Lines for Leaks
But could also be the lambda sensor
Mk3 ABF 16VT Megasquirt V3
Offline mk3tony
« Reply #2 on: 28 January 2012, 13:27 »
I know i've been through that list thats why I need someone to test for leak, vacuum, boost amd exhaust. Where can the secondary air intake leak? I've just got the hose hanging loose and not connected as got a filter on maf.
