Golf mk4
Wazzzer
catch can fitted AUQ is this correct?
Topic: catch can fitted AUQ is this correct? (Read 2229 times)
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Re: catch can fitted AUQ is this correct?
Reply #10 on:
28 January 2012, 16:43 »
Pretty sure you can ditch the reservoir when you do the bypass
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
jockgti
Guest
Reply #11 on:
28 January 2012, 16:49 »
yeah you can and i think he has,but that pipe is still there if you leave the 4 branch metal bit that sits behind the combi valve
http://forums.vwvortex.com/showthread.php?3111538-DIY-Cleaning-up-Engine-bay...Removing-SAI-N249-PCV-EVAP
Last Edit: 28 January 2012, 16:55 by jockgti
rench
Here all the time
Reply #12 on:
29 January 2012, 18:49 »
so them two hoses should be capped off?
http://www.golfgtiforum.co.uk/index.php?topic=228442.0
Marc87
Reply #13 on:
07 February 2012, 16:02 »
Im sure it doesnt matter about them 2 pipes as the other end is now left open as well??
Golf mk4
Wazzzer
