Golf mk4
Wazzzer
catch can fitted AUQ is this correct?
Topic: catch can fitted AUQ is this correct? (Read 2226 times)
rench
Here all the time
28 January 2012, 11:18 »
fitted catch can but wasnt sure if these 2 pipes needed caping off and this outlet on tip needed caping? alos ive capped the 2 vacum sources of on manifold this correct? cheers
Last Edit: 28 January 2012, 13:41 by rench
http://www.golfgtiforum.co.uk/index.php?topic=228442.0
rench
Here all the time
Re: catch can fitted AUQ is this correct?
28 January 2012, 13:42 »
i also did n249 bypass while i was at it thats why i wasnt sure if i needed to cap those 2 hoses?
Jonnybbad
28 January 2012, 14:02 »
Outlet on tip yes not sure bout other 2 thou I've only done catch can on my AUQ was the n249 easy to do also how's it running now without the 249
rench
Here all the time
28 January 2012, 14:16 »
not run it yet just about to go see, them 2 hoses ive capped of are from doing n249, did you cap both outlets of under manifold? cheers
Jonnybbad
28 January 2012, 14:39 »
Yes
rench
Here all the time
28 January 2012, 14:44 »
just had a run in it seems ok, just need someone to confirm ive done the n249 correct cheers
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Reply #6 on:
28 January 2012, 14:56 »
Where do those pipes actually go?
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
jockgti
Guest
Reply #7 on:
28 January 2012, 15:06 »
do the sai delete and 112 as well clears up loads of stuff,and get a nice silicone TIP in there
jockgti
Guest
Reply #8 on:
28 January 2012, 16:13 »
Quote from: Wazzzer on 28 January 2012, 14:56
one goes to the black reservoir on top of rocker cover and i think the other comes from y jet suction pump you remove with catch can install
rench
Here all the time
Reply #9 on:
28 January 2012, 16:37 »
I'll get a pick to show ware they go
Golf mk4
Wazzzer
