Golf mk2
Car won't start!!
Topic: Car won't start!! (Read 2016 times)
GTI_16V
Car won't start!!
18 May 2005, 12:40 »
Following on from my post this morning about stalling (don't know if they are connected) - my 16v won't start this morning!!
It's trying to start, but is not catching at all - as if there is no fuel getting through. I've noticed that the last couple of mornings that the car has taken a bit longer to start, but it got there in the end. Now this!! Help!! What should i be checking first??
"Do you love that car more than me?" - (Mrs GTI_16V, 2005)
tinman
Re: Car won't start!!
18 May 2005, 13:03 »
Had something similar before the rebuild and it was the distributor that was shagged. Another bad starting problem turned out to be the coil breaking down.
Gambit
Forum addict
18 May 2005, 13:32 »
can u hear the fuel pump prime when u turn the ignition on? u need to check n see if you are getting a spark when turning over.
GTI_16V
18 May 2005, 13:40 »
Excuse my ignorance, but what does prime mean?! I take it, i should be listening out for a noise near the fuel tank when the ignition is on?
Gambit
Forum addict
18 May 2005, 13:54 »
when you turn the ignition to on, do u get a buzzing noise that lasts for about 2-3 secs?
GTI_16V
18 May 2005, 14:10 »
Yes!
GTI_16V
Reply #6 on:
18 May 2005, 16:36 »
Right, got the the car started with a push start and it seems to be running ok. I'm gonna check the plugs and filters etc and hopefully it will be ok. Anything else i should be checking?
GTI_16V
Reply #7 on:
20 May 2005, 12:02 »
Changed filters, plugs and put some fuel cleaner in for good measure and she seems to be running fine!! Nice one!
Cheers!
Gambit
Forum addict
Reply #8 on:
20 May 2005, 12:19 »
did u change the fuel filter also yeah?
Organisys
Old and Slow...
Reply #9 on:
20 May 2005, 12:22 »
If you bumped it ok, and it now runs ok, this could mean it was just a weak battery. Do you do just short trips?
Quote from: Mr Blue on 29 May 2013, 19:15
Golf mk2
Car won't start!!
