Author Topic: Please help mk2 wont re-start after breakdown  (Read 1636 times)
Offline siddleg
« on: 27 January 2012, 17:26 »
My mk 2 golf gti 90 8v which has been fully serviced last June with new leads, plugs dizzy, arm, coil, oil and filters started juddering badly today then broke down and the RAC man came and couldn't get it started. He checked the leads and found the king lead damaged, the porcelin had snapped off into the dizzy and then some of the leads had been arching badly in the dizzy so that was renewed and the leads. I turned it over and it never started to our surprise, so he checked for spark which there was and checked the fuel rail which had fuel pumped to it so with both our heads scratching the car was towed to my local garage. what could it be? it has a cobra immobo but has never caused any probems before and surely it would cut something out?
any advice would be great thank you
Offline apie2004
Re: Please help mk2 wont re-start after breakdown
« Reply #1 on: 27 January 2012, 19:54 »
MAF? I had a similar issue and one of the wires to the MAF had rubbed through
Offline clipperjay
« Reply #2 on: 28 January 2012, 10:54 »
Are you sure you have put all leads back correctly? (firing order) easy mistake to be made esp when you in a rush to get it started again?
Offline siddleg
« Reply #3 on: 28 January 2012, 14:22 »
well ill check the maf as you never know.
yes lead fitted correctly watch the RAC man do it one off one on.
ill call the garage on Monday and ask him to check the maf.
