The garage
brake bleeder
Topic: brake bleeder (Read 2528 times)
mkviken
brake bleeder
26 January 2012, 22:10 »
I'm going to fit braided brake lines to the car and I'm due a change of brake fluid on my other car so might as well buy a decent bleeder
can anyone recommend me a good DIY bleeder.
I'm thinking of buying a used compressor but if i can get a bleeder with doesn't need one it would be handy.
also does the clutch need bleeding when i do the brakes or can i get away with not doing it?
cheers
Golf GTI 7.5 230 white silver
Hoggy
Here all the time
Mk4 GT TDI 150.
Re: brake bleeder
26 January 2012, 22:19 »
Why not do it the old fashioned way by just pumping the pedal to get the fluid to bleed through?
And the clutch wont need bled.
mkviken
Re: brake bleeder
26 January 2012, 22:31 »
its easier if i can do a 1 man bleed. always done the old fashioned method on my bikes but with the car i would need another person.
i would be using VW brake fluid and my car is 4 months old so contamination of any left over fluid in the clutch system shouldn't be a problem but you never know.
AudiA8Quattro
Forum addict
Re: brake bleeder
27 January 2012, 11:06 »
More expensive but worth every penny.
http://www.ebay.co.uk/itm/VS820-BRAND-NEW-SEALEY-BRAKE-CLUTCH-FLUID-BLEEDING-BLEEDER-SYSTEM-TOOL-/260912315927?pt=LH_DefaultDomain_3&hash=item3cbf95fe17
Lurky
Re: brake bleeder
27 January 2012, 11:21 »
Or a sealey vs0205 automatic brake and clutch bleeder little bit cheaper if you dont want to spend that much and it connects onto the tyre instead of having to pump for pressure comes with a few different resevoir caps aswell for most common makes.
We sell quite a few of them and get good feedback from them
mkviken
Re: brake bleeder
27 January 2012, 15:23 »
I've been looking at both of them actually but also the VS020 type which runs of a compressor and fits onto the bleed nipple.
I've got my eye on a few compressors on ebay so might be a better job?
does the type which uses the spare tyre actually work? i would be a bit worried about blowing the reservoir or if the cap pops off and blows fluid all over the car!
cheers
AudiA8Quattro
Forum addict
Re: brake bleeder
Reply #6 on:
27 January 2012, 16:26 »
The bleeders that work off the spare tyres are ok, but i kept on getting air pressure leaks, so i gave up and bought the VS820.
Great piece of kit.
mkviken
Re: brake bleeder
Reply #7 on:
27 January 2012, 17:33 »
yeah they do look good and are only about £50 if you shop around
im bidding on a compressor on ebay so will see how it goes.
The garage
brake bleeder
