Author Topic: steering help?  (Read 2231 times)
Offline chrismac89
steering help?
« on: 26 January 2012, 11:20 »
am going to be putting a 16v engine in my golf but i have non power steering atm, is it possible to remove the power steering pump from a KR engine?
or would it be easier to just get hold of a PAS rack?
cheers
chris
Offline clipperjay
Re: steering help?
« Reply #1 on: 26 January 2012, 12:03 »
Make a list mate
pump
Alternator brackets
Pulleys
Belts
tensioner etc.
Best to take all off it from donor car, before you do it, or even spend some time looking for the right parts
Offline rob.043
Re: steering help?
« Reply #2 on: 26 January 2012, 14:30 »
the PAS may be run on a seperate belt/pulley from the alternator/water pump- going on what i remember from photos (ive got a non PAS 8v)
Are you wanting to run it without the power steering?
Offline Seanl
Re: steering help?
« Reply #3 on: 26 January 2012, 18:13 »
Yep, PAS belt is independant of Alternator, water pump etc.......... They run off a seperate and longer V belt.  :smiley:
Offline chrismac89
Re: steering help?
« Reply #4 on: 26 January 2012, 23:28 »
So I can jus remove the pump and belt and that will work?
Chris
Re: steering help?
« Reply #5 on: 26 January 2012, 23:48 »
Chris
Yes :afro: to fit the rest of the pas set up is a lot of work.
Offline chrismac89
Re: steering help?
« Reply #6 on: 27 January 2012, 08:52 »
thanks alot lads really helped me out.
cheers
chris
