Author Topic: mk2 widetrack.....  (Read 6102 times)
Offline manxpb
mk2 widetrack.....
« on: 25 January 2012, 21:22 »
hi guys, i'm running my mk2 gti on a mk3  widetrack setup, using '95 mk3 gti 16v brakes, subframe etc.
its on 5 stud, but i'd like to switch back to 4 stud, is it possible to get back to 4 stud while keeping the wide track??
the rear isnt gonna be a problem, but the front is making my brain hurt!
Offline lemski
  • 16v
Re: mk2 widetrack.....
« Reply #1 on: 25 January 2012, 21:26 »
U can. Get the hubs and such. Not sure if the ball joints are differant though
Offline manxpb
« Reply #2 on: 25 January 2012, 21:31 »
yeah, i thought the balljoints were different, and the cvs too. probably should have been more specific, but what im wanting to do is just change the discs and drive flanges if possible, just not sure if theres anything that fits the bill, i heard some of the early passats used a 4 stud version of the mk3 setup? could be wrong.
« Reply #3 on: 25 January 2012, 23:50 »
Not sure on Passat but Vento and Cabrio 2.0 mk3's were 4 stud.
Offline lemski
  • 16v
« Reply #4 on: 26 January 2012, 09:19 »
Were the cabrios 288 discs? The only one I can think of is the g60 setup on the front. Could keep your caliper then I should think. But u'd need the hubs of a corrado (think there 4 stud)
Offline mad4vws
« Reply #5 on: 27 January 2012, 21:07 »
lot of differece in 4 stud from 5 firstly the wishbones are different ,driveshalfts subframe anti-rolebar etc... :wink: :smiley:
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline Diamond Hell
  • Opinions я Us
« Reply #6 on: 27 January 2012, 21:26 »
Correct, but if you look at the components there are the bits out there that were in use on other vehicles to make it work.
B3 Passat GT 16V had 280mm front discs and 4-stud and wide-track for sure.
Get out your ETKA and figure out the uprights, caliper carriers, balljoints to make it work.
Offline popleyruss
« Reply #7 on: 30 January 2012, 22:31 »
Hold tight on that one I'm in the proces of having these made up and will have a few sets avalible ;)
Just plain dubbin
Offline WYATT
« Reply #8 on: 06 February 2012, 00:15 »
ive spoke to a fair amount with 4 or 5 stud and a couple said 5 stud handles like a dream! / the wishbones and ball joints sit and nicer angles so ive heard ?
i run 4 stud personally and think it handles spot on !?
Offline Ben Lessani
« Reply #9 on: 07 February 2012, 22:50 »
