Author Topic: Alternator randomly stops  (Read 1038 times)
Offline Yohan
« on: 25 January 2012, 15:06 »
Afternoon,
Seems I have an Alternator issue.
Firstly it rarely charges above 14.0v, usually between 13.0 - 13.5v.
Twice now I have started the car first thing in the morning and shortly after there is a loud click/clunk noise, all the lights dip, the engine grunts, and the voltage level drops to 11.5v.
Before I can pop the bonnet to go and look, the voltage goes back up to 13.5v again.
I have in the past couple of weeks had a screaching from the aux belt area as well.
Does this sound like a dodgy voltage regulator and alternator pulley?
Or should I just get the whole lot replaced?
Offline richw911
Re: Alternator randomly stops
« Reply #1 on: 25 January 2012, 15:51 »
Check all the earth's and the fuse box on top on the battery for damage / melting  :wink:
Offline Yohan
« Reply #2 on: 30 January 2012, 08:45 »
All earths look clean, fuses are all dandy, and nothing has melted.
The car had been sitting since Friday night, when I turned it on this morning the voltage gauge dropped to 11.5v, the car started spluttering and misfiring and generally sounded rough.
After a few seconds the alternator kicked in, voltage rose to 13.5v and the engine started running nice and smoothly again.
Would a jammed alternator pulley cause the engine to misfire like this?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 30 January 2012, 12:27 »
Maybe mate, once it jams I guess it could draw power off the battery rather than recharging it.
