Author Topic: 16V engine stalling when cold  (Read 1797 times)
Offline GTI_16V
« on: 18 May 2005, 08:00 »
Hi, a little bit of help on my (hopefully) minor problem would be appreciated!
When my valver is cold it stalls whenever i stop revving.  It normally cuts out when i rev it above 2000rpm then let it drop to idle.  If  i let the revs drop slowly to idle it seems to fine - it only happens when the revs are dropping a bit faster (i.e. when i rev it then let it drop).  Once the car is warmed up it is fine.  Any suggestions??
"Do you love that car more than me?" - (Mrs GTI_16V, 2005)
Judderi
Re: 16V engine stalling when cold
« Reply #1 on: 18 May 2005, 09:35 »
Sounds like a problem with the ISV (idle stabalization valve) to me. Take it off and give it a clean with some brake cleaner or petrol.
Offline Gambit
Offline GTI EDITION (aka LTD)
« Reply #3 on: 18 May 2005, 10:38 »
see this first!!
http://www.golfgtiforum.co.uk/index.php?topic=22031.0
This link has some good advice , the only thing that I would change/add is that the when the 16V s first came out they tended to suffer with idle/stalling problems .
1)  I believe that the ignition should be switched off when disconnecting and connecting  the red lead .
2) VW sent  updated tuning data which if I remember correctly stated that the idle speed should be adjusted to 1000 +/- 50 rpm instead of the previously stated 950 +/- 50 rpm
3) make sure the throttle cable is not too tight so as not to allow the throttle idle switch to close  .( I had a customer that kept fiddling with the cable adjustment  on his and then wondered why it kept stalling .... the penny eventually dropped ! ....now it idles properly .
P.S.  I also have changed the idle stabilization valves for modified ones  ( modded ones had a yellow sticker on them ) but this was back in the 80s so I would imagine they have all been done by now unless some may not have being that it was not a recall as such. :smiley:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Offline Gambit
« Reply #4 on: 18 May 2005, 10:59 »
good info, ill bung this is with sticky!
Offline tinman
« Reply #5 on: 18 May 2005, 11:30 »
I wouldn't go ISV to start with.
Check the Idle Stabilisation controller in the centre console. Find it and disconnect it. If the car does exactly the same thing with or without it - then its boogered.
Find a smashed 16v - theres one a week on the forum and give the owner a fiver for it. If you buy it from VAG - expect it to cost around 120quid.
« Reply #6 on: 18 May 2005, 12:02 »
You're quite right about the control unit behind the center console I completely forgot about that ...long time since having probs with one ... I'm not definite on this but I have a vague recollection that the control units were replaced as well..... way back when... but don't quote me on that :undecided:
Offline GTI_16V
« Reply #7 on: 18 May 2005, 12:51 »
Excellent information - thanks!   Just need to get the bloody thing started now in the first place!!  (see todays other post from me!!)
