Author Topic: engine swap / gti engine wanted as well as advice  (Read 890 times)
Offline Tucky
  • why do it today when you can put it off untill tmz
« on: 24 January 2012, 18:06 »
Hi again all got the match today turns out shes a 1994 with 95k on the clock. If i cant get the issue with 2nd gear sorted (think it maybe the linkage ) im thinking of putting a gti lump and box in. How much effort is envoled  plus is it simple plug and play or do i need to change wireing loom etc, and also if any of you helpfull chaps have any engines and boxs that your getting shot of please let me know .
Re: engine swap / gti engine wanted as well as advice
« Reply #1 on: 24 January 2012, 20:18 »
Not worth the hassle or work, so much needs changing that the swap is not worth it for the gains you will get back.
Offline rmas
« Reply #2 on: 01 February 2012, 12:21 »
so you have a 1.4 and want to swap engine to a 2.0? if so i just did something similar to mine (1.6 to 2.0) and if you can source a donor car i dont think its much of a trouble and i see the parts there are actually nice then here so if you need some pointers just let me know, cheers
