Author Topic: Can I change my cluster language with this...  (Read 926 times)
Offline Chris#101
« on: 24 January 2012, 17:45 »
How do, my cluster language appears to be in Spanish or simlar!?  :laugh:
Can I change it with my new toy I aquired!? if so guidance would much be appreciated
heres what I have
http://www.ebay.co.uk/itm/150667799048?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
cheers
« Last Edit: 24 January 2012, 17:47 by Chris#101 »
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline topher
  • Administrator
  • fully functioning
Re: Can I change my cluster language with this...
« Reply #1 on: 24 January 2012, 18:40 »
you need vagcom 311.2 or higher i believe
Offline james2
  • No scammers please.
« Reply #2 on: 24 January 2012, 22:46 »
heres what I have
cheers
you cant change anything with that.It only shows fault codes / delete them. Good tool .
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
