Author Topic: Disabling Oil Light  (Read 1466 times)
Offline mrpatterson2008
Disabling Oil Light
« on: 24 January 2012, 14:35 »
Hi, i've got a mk4 golf, 2000 reg.  The oil light is always coming on but its just my cheap run about so i'm not going to bother fixing it.  However its really annoying having the light and sounder always coming on.
Does anyone know how to disable the light and sounder, or even just the sounder.. ( I don't mind a bodge job) lol
Offline T_J_G
Re: Disabling Oil Light
« Reply #1 on: 24 January 2012, 14:48 »
Pressure or oil level?
« Reply #2 on: 24 January 2012, 14:57 »
Pressure
« Reply #3 on: 24 January 2012, 15:13 »
Pressure
Have you checked the pressure, not good that it keeps coming on, you could be doing damage.
« Reply #4 on: 24 January 2012, 15:20 »
Oh im sure its doing damage.
No doubt it'll be alot of work to fix it tho?
The car has 133k on it, 1.4 16v. I was just going to buy a new one when it totally dies.  Or drop another engine in.
Offline Darksider1.8T
« Reply #5 on: 24 January 2012, 16:11 »
tbh mate if your not bothered if its doing any damage then why do you want it off?
fixing the oil pressure problem will get rid of the light and noise
« Last Edit: 24 January 2012, 16:13 by Darksider1.8T »
Offline james2
  • No scammers please.
« Reply #6 on: 24 January 2012, 22:36 »
I would leave it, the engine could die tomorrow.  :wink:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline mcgee9t2
« Reply #7 on: 24 January 2012, 23:02 »
could it just be a simple fix like oil pick up pipe?
surely its better to get the problem sorted than be halfway home the car then dies and you have to get recoverd, could end up being you conk out on a really busyroad or a blind corner then someone crashes into you and its bye bye golf/bye bye having no accidents on insurance or could be worse.
« Reply #8 on: 25 January 2012, 08:33 »
Well how would i go about finding the problem ?
The reason i wanted it disabling is just because the beeping every ten minutes is annoying
« Reply #9 on: 25 January 2012, 09:12 »
if its something do with the pressure id say check oil level if its ok and there is no tapping or knocking, then it could be something as little as a pressure sensor if not then id say oil pump
