Author Topic: Pipe covered in oil. AGU  (Read 3456 times)
Offline MaXXeH
  • Golf MK5 GTI
Re: Pipe covered in oil. AGU
« Reply #10 on: 23 January 2012, 19:35 »
just take them off and get the pn :P
Offline james2
  • No scammers please.
« Reply #11 on: 23 January 2012, 19:54 »
COOL i found it .How much will these bits cost, any ideas ?  :smiley:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #12 on: 23 January 2012, 20:01 »
you don't even need that pipe with a catch can  :laugh:
Offline richw911
« Reply #13 on: 23 January 2012, 20:03 »
How much do you "catch" out of intrest Wez?
Offline james2
« Reply #14 on: 23 January 2012, 20:04 »
i might leave number 6 (bleeder vavle) as i might be able to clean it out , i dont know whats in it.  :undecided:
Offline james2
« Reply #15 on: 23 January 2012, 20:06 »
I want to try it all fixed and see if i still get loads of oil in the intercooler. If i do ill get a catch tin.  :wink:
Offline james2
« Reply #16 on: 23 January 2012, 20:40 »
god it going to cost over £80.  :cry: ill have to leave it for a while. :embarassed:
Offline james2
« Reply #17 on: 23 January 2012, 23:20 »
cool old mans buying all the parts :kiss:. How you clean a bleed valve. I want to leave that/ save £22 ???
Offline Chris.
« Reply #18 on: 23 January 2012, 23:52 »
Why not just remove the T valve? NUmber 5.  And cap the boost from inlet?
Remove 5 and connect part #2 to part # 9 with a bit rubber pipe
Click For Build Thread
Offline james2
« Reply #19 on: 24 January 2012, 00:08 »
its got a bleed valve no:6 .Help i know jake sh!t about what it all does. All i know is its leaking oil and my intercoolers full and  :lipsrsealed: i need it sorted big time. The pipe that goes to the oil filter, is it full of oil.? I was going to sell the car had it ,parts way to much. And common parts that fail cost a bomb.  :angry:
